SCIENTIFIC CALCULATOR
FOR THE PALM HANDHELD COMPUTER
MODEL
SC-103PC
INSTRUCTION MANUAL
INTRODUCTION
With the program SC-103PC you get a powerful and freely available scientific calculator for the Palm platform. Apart from scientific functions it also offers a full set of logical operations and conversions between different numeric systems. Additionally the calculator offers a currency mode for easy conversions between 17 different currencies as far as calculations with mixed currency units. The program is designed in a way, that it simulates the visual and operational aspects of a true calculator, such that the user will be immediately familiar with its interface.
CONTENTS
1. BACKGROUND
The calculator program SC-103PC can be executed on all devices equipped with the Palm Operating System version 2.0 or higher. In addition, it requires the freely available MathLib which is shipped as part of the calculator for your convenience.
The calculator program automatically adapts to single and multi color devices. Starting with version 1.26 of the SC-103PC, high resolution displays of SONY Clié devices and devices equipped with Palm Operating System version 5 or higher are also automatically detected and supported. There is no need for different versions of the program.
The calculator SC-103PC is shipped in three different languages: English, german and esperanto. Only menu items and dialog boxes have been translated; key and display labeling is identical in all versions. To select the desired language, you have to install the proper program module. Since the name of the program module is the same for all languages, you can only have one language version installed at the same time.
Installation of the SC-103PC on the Palm Device
The calculator program SC-103PC as well as the MathLib have to be installed on your Palm device. The SC-103PC uses the MathLib for some of its calculations. If you don't know, how to install additional applications on your Palm device, please refer to the instruction manual which is shipped with your Palm device.
Installation Procedure:
  1. First, install the file MathLib.prc on your Palm device, if it isn't already installed.
    NOTE: Due to the fact that the MathLib is required by many Palm applications, it is probably already installed on your Palm device and you don't have to install it again. (The MathLib is not visible as an application. If you are not sure if the MathLib is already on your Palm device, then simply install it to be safe.)
  2. Select one of the available language versions of the SC-103PC. You find the various language versions in the subdirectories english, deutsch and esperanto. Install file SC-103PC.prc from the selected subdirectory on your Palm device as usual.
  3. Now you should find an application called SC-103PC in the category "unfiled". If you select the corresponding symbol, the SC-103PC will be displayed.
Preferences
To display the preferences window, select the menu item "Preferences...", which is located in the "Options" menu.
Format of Number Display
You can specify how the calculator should display the numbers. If you select "Localized number format", then seperator characters for numbers are used according to the global system preferences. Otherwise, commas are always displayed as dots and spaces are used to separate groups of three digits. Separator characters for groups of three digits will, however, only be used if you select "grouped" number display mode. In "compact" mode digits are displayed with equal spacing. Number settings only have effect in SCIENTIFIC and CURRENCY mode, the appearance of numbers in LOGIC mode can not be changed.
NOTE: All examples shown in these operating instructions assume that the "Localized number format" is not active and that the compact number display is selected. If you use other settings, then numbers displayed on your device may appear in a different format.
Flickering of the Display
You can control the flickering effect of the displayed numbers while pressing an operator key like . You can enable and disable the flickering and additionally you can specify the amount of time the display will be hidden to cause the flickering effect.
The flickering of the display serves as a visual feedback to show you that the calculator has accepted your input. In addition, the pressed key will be highlighted but this effect is often not noticable during fast input because of the delay time of the usually used liquid crystal displays.
The flickering effect of the display can be made stronger or softer. If a greater hide time is selected, the display will be hidden for a longer time and the flickering effect will be stronger. Select a value according to your personal taste.
Note: If the flickering effect is enabled, then the display will be dark as long as you press a key. If you release the key before the selected hide time is reached, then the display will stay dark at least until the selected hide time is over. Not all keys, e.g. number keys, result in a flickering effect of the display because some result in a visual display change anyway and also to simply prevent a too nervous display.
1. OPERATING MODES
The calculator SC-103PC offers three general operating modes for different tasks. To select the desired operating mode there are the three vertically arranged fields at the right border of the display which are labeled SCIENTIFIC, LOGIC and CURRENCY. To select the desired operating mode, tip on the corresponding field with the stylus. The field indicating the currently selected mode is shown in a dark background color.
On color devicesOn B/W devices
SCIENTIFIC
mode
LOGIC
mode
CURRENCY
mode
In SCIENTIFIC mode, the SC-103PC acts like a scientific calculator with 14 digits. In LOGIC mode, conversions between four different numeric systems are possible and basic arithmetic calculations and boolean operations can be performed. In CURRENCY mode, conversions between 17 different currencies and mixed currency calculations can be performed.
2. SCIENTIFIC MODE
The Palm handheld can be used like a calculator with 14 digits. For that purpose the program SC-103PC has to be switched into SCIENTIFIC mode. You can activate the SCIENTIFIC mode by tapping on the corresponding field at the right border.
This is how the calculator in SCIENTIFIC mode looks like:
Calculations
Now we will perform some simple calculations. Press the following keys and look at the display:
InputDisplay
123123.
123.
654654.
777.
Did you get the right result? If not, press the key and try the same calculation again.
Next, the value of pi () should be recalled. The symbol "" is located above the key . Press the symbol.
InputDisplay
3.1415926535898
The Display now shows the value of .
Now 104 should be calculated. For this operation the function 10x will be used.
InputDisplay
4 10000.
Following the most important keys will be outlined:
*  (Clear) (red rsp. dark key)
If this key is pressed immediately after input of numerical data or after a recall of the memory contents, this data will be cleared. In any other case, pressing the key clears the operator and/or the numerical data which have been entered. The content of the memory will not be cleared by pressing the key.
InputDisplay
123  456 456.
0.
786 912.(123 + 789 = 912)
6  2 12.
0.
6  2 12.
5 8.
The key can also be used to clear an error condition.
InputDisplay
5  0
*  (Display mode switch)
With this key you can switch the display mode for the result of a calculation from floating point system (normal mode) to fixed point system (FIX), scientific notation (SCI), engineering notation (ENG) or vice versa.
InputDispay
23  1000
*  (specifies the number of decimal digits)
In comibation with a number key, this key can be used to specify the number of decimal digits (digits after the decimal point). Press the clear key so that "0." is displayed. Press the key , then "0.000" (FIX mode) appeares on the display.
1. Specification of 2 decimal digits.
InputDisplay
2
5 8
2. Specification of 5 decimal digits.
InputDisplay
5
*  (specifies the angular mode)
This key is used to specify the angular mode for numerical data for trigonometric functions, inverse trigonometrc functions and coordinate transformations.
InputDisplay
(Degree)
(Radian)
(Grad)
(Degree)
180° = (rad) = 200g
DEG: Degree [°]
RAD: Radian [rad]
GRAD: Grad [g]
*  (transforms between angular modes)
This key is used for transformations between angular modes and simultaneously specifies the angular mode for numerical data for trigonometric functions, inverse trigonometrc functions and coordinate transformations.
InputDispay
180(Degree)
(Radian)
(Grad)
(Degree)
*  to , , and
: Used to enter numbers in exponential notation (an "E" following the entered number appears on the display).
InputDisplay
4 34.E 003(4 × 103)
4000.
-4000.
: Used to enter negative numbers (or to inverse the sign from negative to positive).
InputDisplay
1.23 -1.23
5 -1.23E-005(-1.23 × 10-5)
-0.0000123
0.0000123
*  (Backspace)
With this key the last entered digit can be deleted.
InputDisplay
125125.
12.
3123.
 478478.
47.
4.
56456.
579.(123 + 456 = 579)
1.456  191.456E 019
1.456E 001.
21.456E 012.
 1000 1456000000.(1.456 × 1012 / 1000 = 1456000000)
Basic Usage
1. Addition and Subtraction
Input: 12 45.6 32.1 789 741 213
Result: 286.5
2. Multiplication and Division
a. Input: 841 586 12
Result: 41068.833333333
b. Input: 427 54 32 7 39 2
Result: 595.85714285714
Note that multiplication and division have priority over addition and subtraction. Internally, the calculator first calculates the multiplication and division.
Multiplication with a constant:
The value entered first acts as a constant.
Input: 3 5 Result: 15
Input: 10 Result: 30
Division with a constant:
The value entered after the division sign acts as a constant.
Input: 15 3 Result: 5
Input: 30 Result: 10
Note:
Depending on the priority, the calculator puts some calculations in pending state. In case of chain calculations, the last calculation instruction, taking into account the priority rules, and the relevant numeric value are retained and can be used for further calculations or as constants, respectively.
a + b × c =+ bc(Constant addition)
a × b ÷ c =÷ c(Constant division)
a ÷ b × c =a/b ×(Constant multiplication)
a × b - c =- c(Constant subtraktion)
3. Memory Calculations
The independently accessible memory can be maintained with the three keys , and . Before starting a calculation clear the memory by pressing and .
If a value other than zero is stored in memory "" is displayed.
Input: 12 5
Result: 17
For subtraction enter: 2 5
Result of this equation: -7
Enter to recall memory contents: 10 will be displayed.
Input: 12 2
Result: 24 (replaces 10 in memory)
Input: 6 2
Result: 4
: 28
To subtract a value from memory contents, the keys and can be pressed.
In addition to the memory which can be modified with the key, there are 10 memory slots available which can be modified with to .
To read the contents of these memories you have to press the keys to just like for the independently accessible memory.
Scientific Calculations
To calculate trigonometric and inverse trigonometric equations and for coordinate transformations the angular mode has to be assigned. The assignment of the angular mode DEG, RAD or GRAD happens by pressing the key.
1. Trigonometric Functions
Exercise: sin 30° + cos 40°
Angular mode to DEG
Input: 30  + 40   Result: 1.266044443119
Exercise: cos 0,25
Angular mode to RAD
Input: 0.25     Result: 0.7071067811865
2. Inverse Trigonometric Functions
Exercise: sin-1 0,5
Angular mode to DEG
Input: 0.5 Result: 30
Exercise: cos-1 -1
Angular mode to RAD
Input: 1 To input a negative number, press the
key after entering the number.
Result: 3.1415926535898 (Value of )
The results of inverse trigonometric functions are only valid between the following ranges:
 = sin-1 x,  = tan-1 x  = cos-1 x
DEG: -90 <=  <= 90 [°] DEG: 0 <=  <= 180 [°]
RAD: -/2 <=  <= /2 [rad] RAD: 0 <=  <=  [rad]
GRAD: -100 <= <= 100 [g] GRAD: 0 <= <= 200 [g]
3. Hyperbolic- and Inverse Hyperbolic Functions
Exercise: sinh 4
Input: 4 Result: 27.289917197128
Exercise: sinh-1 9
Input: 9 Result: 2.8934439858859
4. Power Functions
Exercise: 202
Input: 20 Result: 400
Exercise: 33 and 34
Input: 3 3 Result: 27
Input: 3 4 Result: 81
5. Roots
Exercise: Square root of 25
Input: 25 Result: 5
Exercise: Cube root of 27
Input: 27 Result: 3
Exercise: Fourth root of 81
Input: 81 4 Result: 3
6. Logarithmic Functions
Exercise: ln 21, log 173
Natural Logarithms
Input: 21 Result: 3.0445224377234
Common Logarithms
Input: 173 Result: 2.2380461031288
7. Exponential Functions
Exercise: e3,0445
Input: 3.0445 Result: 20.999528813094 (see ln 21)
Exercise: 102,238
Input: 2.238 Result: 172.98163592151 (see log 173)
8. Reciprocals
Exercise: 1/6 + 1/7
Input: 6 7 Result: 0.3095238095238
9. Factorial
Exercise: 170!
Input: 170
Result: 7.257415615308E 306 (= 7,257415615308 × 10306)
On calculating the factorial it is easily possible to overflow the calculation limits of the SC-103PC which results in the error indication "E". The section Calculation Range discusses the calculation limits of the calculator.
Exercise: 8P3 = 8!/(8-3)!
Input: 8 8 3
Result: 336
10. Percent calculations
Exercise: 45% of 2780 (2.780 × 45/100)
Input: 2780 45 Result: 1251
Exercise: 200 - 200 × 30/100
Input: 200 30 Result: 140
11. Angle/Time conversions
To convert an angle or time (°, ', ", rsp. hours, minutes, seconds) to its decimal equivalent the degrees have to be given as integer portion and the minutes and seconds as decimal digits.
Exercise: Transformation of 12°47'52" to its decimal equivalent
Input: 12.4752 Result: 12.797777777778
When converting decimal degrees to the equivalent degrees/minutes/seconds, the answer is broken down:
integer portion = degrees; 1st and 2nd decimal digits = minutes; 3rd and 4th digits = seconds; and 5th through end decimal digits are decimal seconds.
Exercise: Conversion of the decimal angle 24.7256 to its degree/minute/second equivalent
Input: 24.7256 Result: 24.433216 or 24°43'32"
A horse has leap times of 2 minutes 25 seconds, 2 minutes 38 seconds and 2 minutes 22 seconds. What is the average running time? Result 2: 0.0412037037037
Input: 0.0225 0.0238 0.0222
Result 1: 0.1236111111111
Input: 3
Input:
Result 3: 0.0228333333333
or the average time is 2 minutes 28 seconds.
12. Coordinate Conversion
Converting rectangular coordinates to polar (x, y  r, ).
DEG:
RAD:
GRAD:
0 <= | | <= 180
0 <= | | <=
0 <= | | <= 200
Convert rectangular coordinates x = 6 and y = 4 to polar coordinates.
Angular mode: DEG
Input: 6 4 Result: 7.211102550928 (r)
Input: Result: 33.69006752598 ()
Calculate the magnitude and direction (phase) in a vector i = 12 + j9
Input: 12 9 Result: 15 (r)
Input: Result: 36.869897645844 ()
Converting polar coordinates to rectangular (r,   x, y).
Solve for P(14, /3), r = 14, 0 /3
Angular mode: RAD
Input: 3 14
Result: 7 (x)
Input:
Result: 12.124355652982 (y)
Hint:
In the above example  = /3 is entered first and is replaced by r = 14 by pushing the key after entering r.
Usage of the Parenthesis Keys
Usage of the parenthesis keys and is required if series of calculations are combined together and the priority of operations has to be changed.
After pressing the key, "( )" is displayed in the top of the display.
Calculations between parenthesis have priority over all other calculations. The parentheses can be nested more than once. First the calculations between the innermost parenthesis will be made.
Exercise: 12 +42 ÷ (8 -6)
Input: 12  42   8
Result: 33
Exercise: 126 ÷ {(3 + 4) × (3 - 1)}
Input: 126    3  4    3  1
Result: 9
Hint:
It is not neccessary to close the parenthesis immediately before the key (or key).
Decimal Digits
The number of decimal digits in a calculation result can be specified; to do this use the key in combination with the keys to . In this case, the display has to be switched to fixed point (FIX), scientific notation (SCI) or engineering notation (ENG).
No decimal digits.
(The number will be roundet to the next integer number.)
One decimal digit.
(The number will be roundet to the first decimal digit.)
Nine decimal digits.
(The number will be roundet to the 9th decimal digit.)
To clear the TAB setting (definition of places after decimal digit) leave the calculator application and restart it again. Then the normal display will be shown again.
Example:
9
0.5 9 0.055555556 (FIX mode)
(The number is roundet to the 9th place after decimal digit.)
5.555555556E-002 (SCI mode)
(The mantissa is roundet to the 9th place after decimal digit.)
5.556E-002 (SCI mode)
(The mantissa is roundet to the third place after decimal digit.)
55.556E-003 (ENG mode)
0.0555555555556
Priority Levels of Operations
The program is provided with a function that judges the priority level of individual calculations; thus, you can enter your calculations in the same order as in a given mathematical formula. The following table shows the priority level of individual calculations.
1. Functions as sin, x2 or %
2. yx,
3. ×, ÷
4. +, -
5. =, M+
(Calculations which are given the same priority level are executed sequentially.)
Example:
Key operation and sequence of calculation in 5 + 2 × sin 30 + 24 × 53 =
The numbers - show the sequence of the calculations.
When calculations with higher priority are executed, those with lower priority must be saved in the meantime. The program is equipped with additional memories for such pending operations.
As these memories are also used for calculations with parentheses, calculations can be performed according to a given mathematical formula unless parentheses and pending operations exceed 30 levels in total.
Calculations without Parentheses
Example:
Pending of 1 level
Pending of 2 levels
Pending of 3 levels
By pressing the key, 3 pending levels are reached. After pressing the key the calculations "yx" will be performed with highest priority and "×" with the same priority. Thus, after pressing the key, two pending levels remain.
Calculations with Parenthesis
Example:
i)4 numbers and operations stay pending.
ii)After pressing the key first the calculation between parentheses 3 - 4 ÷ 5 will be performed; 2 calculations stay pending.
3. LOGIC MODE
Computer engineers and programmers are in need of simple conversions between various numeric systems as well as for calculations with boolean logic. With the calculator SC-103PC this problem is solved by providing the LOGIC mode. The LOGIC mode can be selected by tapping on the corresponding field at the right border.
Note:
You should first read the sections "Calculations" and "Basic Usage" in the chapter "3. SCIENTIFIC MODE", to get familiar with the operation of the calculator and its basic functions before you use the LOGIC mode.
This is how the calculator looks in LOGIC mode (hexadecimal notation selected):
The calculator can operate with integer values up to a bit width of 32 bits in four different numeric systems.
Conversion Between Different Numeric Systems
To convert a number to its hexadecimal equivalent; at the same time the calculator will be switched to hexadecimal notation HEX. ( is shown in the displayed.)
To convert a number to its decimal equivalent; at the same time the calculator will be switched to decimal notation DEC. ( is shown in the display.)
To convert a number to its octal equivalent; at the same time the calculator will be switched to octal notation OCT. ( is shown in the display.)
To convert a nubmer to its binary equivalent; at the same time the calculator will be switched to binary notation BIN. ( is shown in the display.)
Exercise:
Conversion from decimal 30 to hexadecimal notation:
Press key if calculator is not currently in decimal notation ( is displayed).
InputDisplay
30 1E
Exercise:
Further conversion of hexadecimal 1E to binary format:
InputDisplay
11110
The Hexadecimal Notation
The hexadecimal notation system is mainly used in computer programming. The base for a hexadecimal number is 16; hexadecimal numbers consist of the digits 0 to 9 and the major letters A to F, which stand for the numbers 10 to 15 in the decimal system.
Keys for the letters A to F will be shown as soon as the calculator is in hexadecimal notation. The symbol means, that numerical values on the display are shown in hexadecimal notation and that basic integer arithmetic and boolean operations can be performed.
The Decimal Notation
In LOGIC mode even in decimal notation only integer values with a bit width of a maximum of 32 bits can be handled.
In decimal notation only the keys for the digits 0 to 9 are shown. The symbol means, that numerical values on the display are shown in decimal notation and that basic integer arithmetic and boolean operations can be performed.
The Octal Notation
The base for a octal number is 8; octal numbers consist of the digits 0 to 7.
In octal notation only the keys for the digits 0 to 7 are shown. The symbol means, that numerical values on the display are shown in octal notation and that basic integer arithmetic and boolean operations can be performed.
The Binary Notation
The binary notation system is mainly used in computer programming. The base for a binary number is 2; binary numbers consist of the digits 0 and 1.
In binary notation only the keys for the digits 0 and 1 are shown. A smaller font is used so all of the 32 positions can be displayed in one row. Additionally, a ruler is shown above the digits to support the identification of nibbles, bytes and words. The symbol means that numerical values on the display are shown in binary notation and that basic integer arithmetic and boolean operations can be performed.
Direct Bit Manipulation
In the binary notation system a digit can be swapped from 0 to 1 and vice versa by tapping on the digit position below the ruler. If an empty area is tapped then the digit 1 will be set there. With this functionality it is possible to directly modify the bits of a value.
Selecting the Bit Width, Number Display and Sign Mode
The calculator can be switched to bit widths of 8, 16 and 32 bits which are commonly used in the computer industry. With the key the next higher and with the key the next lower bit width is selected. The currently selected bit width is shown in the display.
With the key you can switch leading zeros on and off. Press the key once to show numbers with leading zeros filled to the selcted bit width ( will be shown in the display). Press the key once more to switch back to normal number display. If is activated then leading zeros can be entered during input.
Example:
Settings: , notation,
InputDisplay
1AB 1AB
01AB
0000 01AB
InputDisplay
000AB800 0AB8
0000 0AB8
456 002E 79D0
2E 79D0
With the key, the calculator can be switched between signed and unsigned mode. In the display the symbol appears if the signed mode is active.
Signs are only shown in HEX, DEC and OCT notations. In the BIN notation only the bits are shown, always without a sign.
With the key the sign of a number can be changed. If the sign of a positive number is changed, the 2's complement of the number is calculated. In signed mode the number will then be shown as negative number in unsigned mode as 2's complement.
Example:
InputDisplay
180 -180
FE80
1111111010000000
Number Range
The selected bit width in combination with the sign mode has influence on the number range which can be handled. In contrast to the SCIENTIFIC mode, too big or too small numbers do not lead to an error condition in LOGIC mode but to an overflow.
Bit WidthNum. Sys.Sign ModeNumber Range
8 BITHEX0~FF
8 BITHEXSIGN-80~7F
8 BITDEC0~255
8 BITDECSIGN-128~127
8 BITOCT0~377
8 BITOCTSIGN-200~177
8 BITBIN0~11111111
8 BITBINSIGN0~11111111
16 BITHEX0~FFFF
16 BITHEXSIGN-8000~7FFF
16 BITDEC0~65535
16 BITDECSIGN-32768~32767
16 BITOCT0~17 7777
16 BITOCTSIGN-10 0000~7 7777
16 BITBIN0~1111111111111111
16 BITBINSIGN0~1111111111111111
32 BITHEX0~FFFF FFFF
32 BITHEXSIGN-8000 0000~7FFF FFFF
32 BITDEC0~4294967295
32 BITDECSIGN-2147483648~2147483647
32 BITOCT0~377 7777 7777
32 BITOCTSIGN-200 0000 0000~177 7777 7777
32 BITBIN0~11111111111111111111111111111111
32 BITBINSIGN0~11111111111111111111111111111111
Exercise:
Solve of 250 + 15 with unsigned 8 bit arithmetic (overflow calculation):
Press the key to select decimal notation ( is shown in the display).
Press the until is shown in display.
With the key select unsigned mode (symbol cleared in display).
InputDisplay
250  15  9
Exercise:
Display the result of the last calculation in binary notation:
InputDisplay
1001
Basic Arithmetic Calculations
The arithmetic operations addition, subtraction, multiplication and division can be used like in SCIENTIFIC mode. But only integer values can be handled.
Calculating with Numbers in LOGIC Mode
Exercise:
Addition of two hexadecimal numbers
A4 + BA =
InputDisplay
0
A4 BA 15E
Exercise:
4 × 4 =
InputDisplay
0
4 10
Exercise:
32 bit multiplication of the octal number 73 with the binary number 110 and display of the result as a decimal number
73 oct × 110 bin =
Press until is shown in display
InputDisplay
0
73 111011
110 101100010
354
Exercise:
(12 + D) × B =
InputDisplay
0
12 D
B
155
Exercise:
43A-3CB=
+)A38-2FB=
total
InputDisplay
0.
43A 3CB 6F
A38 2FB 73D
7AC
The following hints have to be noted:
Examples:
Input: E 3 Result: 4
Input: B 3 2 Result: 6
With the modulo operation the remainder of a division can be computed.
Input: E 3 Result: 2
By pressing the key it is possible to calculate the complement of a number in a simple way.
Settings: Unsigned mode (symbol is not shown, notation,
Input: AB Result: FFFF FF55
Boolean Algebra
The operators of the boolean algebra AND, OR, XOR (exclusive or) and NOT can be used. In a logical operation two numbers will be transformed to binary representation (2's complement) and the logical relation will then be evaluated for every bit pair.
The following section will shown the results of the logical operators for these bit evaluations:
AND OR XOR NOT
XYX AND Y
111
100
010
000
XYX OR Y
111
101
011
000
XYX XOR Y
110
101
011
000
XNOT X
10
01
After every bit pair has been assigned the corresponding result (a 1 or a 0) according to the above table, the resulting binary number will be converted back to the selected numeric system. This number is the result of the logical operation.
Example:
With the settings , notation, , please perform the following calculations:
41 AND 27
gives
9
Input: 41  27  Result: 9
41 OR 27
gives
59
Input: 41  27  Result: 59
41 XOR 27
gives
50
Input: 41  27  Result: 50
NOT 3
gives
-4 (2's complement)
Input:3  Result: -4
NOT x can generaly be computed with the equation NOT x = -(x + 1).
Bit Shift Operations
With the keys and it is possible to perform bit shift operations. Thereby the value will be transformed to binary representation and the single bits will be shiftet to the left or the right by the given amount. The result will be transformed back to the selected numeric system which yields the result of the operation.
Bit Shift Right
During the bit shift right operation the single bits of a value will be shiftet to the right by the given amount of positions. This is equivalent to a division by the power of 2.
Example:
Calculation of 80 » 3 is equivalent to 80/23:
decimalbinary
before shifting8001010000
after shifting1000001010
Input:Display:
80 310
In signed mode () an arithmetical shift right will be performed whereas in unsigned mode a logical shift right is executed. Arithmetical shift means that the sign of a number is retained; logical shift right always results in a cleared sign bit, treating all bits equal.
Example:
Arithmetic shift right of decimal -120 about one position (is equivalent to a division by two) and display of the result as binary number:
Settings: ,
Input:Result:
0
120 -120
10001000
1 11000100
-60
Logical shift right of the result from the previous calculation by 2 positions and display of the resulting value in binary notation.
Input:Result:
196
2 49
110001
Bit Shift Left
During the bit shift left operation the single bits of a value will be shiftet the given amount of positions to the left. This is equivalent to a multiplication with the power of 2.
Example:
Calculation of 3 « 2 is equivalent to 3 × 22:
decimalbinary
before shifting30000 0011
after shifting120000 1100
Input:Display:
3 212
Swapping Bytes and Nibbles
With the key the bytes of a 16 bit or 32 bit number will be swapped. This allows conversions from"little-endian" to "big-endian" format and vice versa.
Example:
Settings: Unsigned mode (symbol is not shown), notation,
InputDisplay
1234ABCD1234 ABCD
CDAB 3412
3412
1234
In 8 bit notation the nibbles will be swapped:
Example:
InputDisplay
ABAB
BA
Parenthesis and Priority Levels of Operations
During the processing of complex expressions the calculator follows a set of predefined priorities which determine the sequence in which the operators have to be applied. In LOGIC mode, the same rules for priority of operators and parenthesis are valid as described in SCIENTIFIC mode in section "Priority Levels of Operations" but the additional boolean operators have to be taken into account:
1. Functions like not or x2
2. ×, ÷, mod
3. +, -
4. «, »
5. and
6. xor
7. or
8. =, M+
(Calculations which are on the same priority level are executed in sequence.)
5. CURRENCY MODE
The CURRENCY mode offers easy conversions between 17 different currency units and calculations with mixed currencies. The conversion factors (exchange rate) and currency symbols can be freely defined by the user. The calculator is shipped with the 12 Euro related national currencies and the Euro predefined. Each currency is assigned to a key. The CURRENCY mode can be selected by tapping on the corresponding field at the right border.
Note:
You should first read the sections "Calculations" and "Basic Usage" in the chapter "3. SCIENTIFIC MODE", to get familiar with the operation of the calculator and its basic functions before you use the CURRENCY mode.
This is how the calculator looks in CURRENCY mode (hexadecimal notation selected):
Easy Conversions Between Two Currencies
The CURRENCY mode has a display with two lines. User inputs are displayed in the first line. In the second line the entered or calculated value can instantly be viewed in a different currency. The numbers displayed in the two lines always represent the same value but in different currency units.
* Currency keys , and so on
With the currency keys the currency unit of the number in the first display line can be selected. The key area with the currency keys is surrounded by a thin line. By pressing the key for example the currency DEM will be assigned to the value oft the first line in the display. During input of a number the currency unit can be assigned at any time without effecting the numerical value.
*  (specify second line)
With the key you specify the second display line. The consecutively pressed key will the be related to the second display line instead of the first display line. So by pressing of the currency unit ATS will be assigned to the second line. If the currency unit of the second line will be changed then the numerical value of the second line will also be changed because the value of the first line will be converted to the new currency unit of the second line.
Example:
How many Euro (), are 123.5 austrian Schilling (ATS).
InputDisplay
123.5123.5
8.98
ATS
Showing the 123.5 ATS of the last example in BEF:
InputDisplay
23.5
362.05
ATS
BEF
To start a new conversion, press the key first to clear the display and start a new input.
InputDisplay
0.
0.00
ATS
BEF
527.9527.9
1547.60
ATS
BEF
527.9
38.36
ATS
*  (exchange currencies)
With this key the currencies of the first line and the second line can be exchanged. Only the currency units will be new assigned. The values will not be exchanged.
Example:
Conversions between various currencies.
InputDisplay
    0.
0.00
DEM
ATS
12.612.6
88.65
DEM
ATS
12.6
0.92
ATS
DEM
0.
0.00
ATS
DEM
100100.
14.21
ATS
DEM
*  (clear currency assignement)
If the key is pressed, the currency assignement for the first display line will be removed. So the number in the first display line has no unit. Simultaneously the second display line will be hidden because a value without a unit can not be converted to a number with a unit.
By pressing of  , the second line can be hidden without effecting the first line.
Example:
InputDisplay
    0.
0.00
DEM
ATS
629.9629.9
4431.68
DEM
ATS
 629.9DEM
 629.9
12991.98
DEM
BEF
629.9
In combination with a number key, this key can be used to specify the number of decimal digits (digits after the decimal point). In combination with the key, the number of decimal digits for the second display line can be specified.
To remove the fixed number of digits after the decimal point and switch back to floating point mode press .
Note: The number of decimal digits can not be set during input of a number only after a calculation or after pressing the key.
1. Specification of 3 decimal digits for the first line.
InputDisplay
0.
0.00
ATS
DEM
30.000
0.00
ATS
DEM
5  8 0.625
0.09
ATS
DEM
2. Specification of 5 decimal digits for the second line.
InputDisplay
  50.625
0.08883
ATS
DEM
3. Floating point display for the second line.
InputDisplay
  0.625
0.088834818282
ATS
DEM
Calculations with Mixed Currencies
In CURRENCY mode the basic operations plus percent calculations can be performed as shown in SCIENTIFIC mode. However, currency units will be taken into account. So it is possible to perform calculations with mixed currency units.
Example:
Calculate 120 ATS + 20.5 DEM and show the result in DEM and Euro.
InputDisplay
    0.
0.00
ATS
120120.
8.72
ATS
120.
8.72
ATS
20.520.5
1.49
ATS
20.5
10.48
DEM
37.55628511006
19.20
DEM
The result of calculations with currency units is displayed in the unit of the second operand, if one has been assigned. Otherwise, the unit of the first operand will be used for the result. Not all unit combinations are valid in calculations. The following table shows combinations of operations and their result units:
Unit of operand 1OperationUnit of operand 2Unit of result
A+BB
Anone(illegal op.)
noneB(illegal op.)
nonenonenone
A-BB
Anone(illegal op.)
noneB(illegal op.)
nonenonenone
A×B(illegal op.)
AnoneA
noneBB
nonenonenone
A÷Bnone
AnoneA
noneB(illegal op.)
nonenonenone
By trying to apply a illegal calculation, the calculator will be set into an error condition and the symbol "E" will be displayed. The error condition can be cleared by pressing the key.
On multiplications and divisions the calculator selects no unit for the second operand by default. But a unit can be assigned to the second operand explicitely.
Example:
InputDisplay
    0.
0.00
ATS
10001000.
72.67
ATS
1000.
72.67
ATS
22.
500.
36.34
ATS
InputDisplay
0.
0.00
ATS
10001000.
72.67
ATS
1000.
72.67
ATS
2020.
20.
10.23
DEM
7.106785462526
After pressing an operator key (, etc.) or the keys rsp. the currency unit assigned to the value in the first line of the display will be shown in bold face. This indicates, that the unit is dedicated to the value. Pressing a currency key in this situation yields to a conversion of the value to the new currency and not the simple assignement of a new currency to the value.
During the processing of complex expressions the calculator follows a set of predefined priorities which determine the sequence in which the operators have to be applied. In CURRENCY mode, the same rules for priority of operators and parenthesis are valid as described in SCIENTIFIC mode in section "Priority Levels of Operations".
Usage of the Memories
The usage of the memories in CURRENCY mode is basically the same as in SCIENTIFIC mode. With a value will be stored in the independently accessible memory and with a value can be added to the current memory contents. Note that currency units are ignored when values are added to memory. No currency conversion is performed. The memory contents can be retrieved with the key like usual.
In addition to the independently accessible memory, 10 memory slots are available as in SCIENTIFIC mode which can be accessed with rsp. followed by a digit key.
Normally the value in the first display line will be stored in the memory. However, by using the key the value of the second display line can be stored. Press one of the following key sequences:  ,   for independently accessible memory or   followed by a digit key to store the value of the second line in one of the 10 memory slots.
Defining Currencies
By default the twelve Euro related national currencies and the Euro are predefined in CURRENCY mode. Additionally, new currencys can be defined, currency definements can be changed or cleared.
The following table shows the predefined currencies with their currency symbols and conversion factors (exchange rates):
CurrencyCurrency symbolExchange rate
Euro*1.0
Austria SchillingATS13.7603
Belgium FrancBEF40.3399
Germany MarkDEM1.95583
Spain PesetaESP166.386
Finland MarkkaFIM5.94573
France FrancFRF6.55957
Greece DrachmaGRD340.75
Ireland PuntIEP0.787564
Italy LiraITL1936.27
Luxembourg FrancLUF40.3399
Holland GuilderNLG2.20371
Portugal EscudosPTE200.482
* On devices which are not equipped with a Euro symbol (), that is, devices with a PalmOS version less than 3.3, EUR will be displayed instead of the Euro symbol.
You can see in the table above that by default the base currency is Euro with has the factor (rate) of 1.0. The exchange ratings of all other currencies are related to the Euro. If a new currency should be defined, the exchange rate of that currency also has to be entered in relation to the Euro or another base currency has to be defined and all exchange rates have to be readapted to the new base currency.
The calculator uses the following formula for currency conversions:
Value2 = Value1 / Rate1 × Rate2
Currency Definition Form
With the currency definition form a new currency can be defined, an existing currency can be modified or deleted. With the menu item "Define Currency Key..." in the "Options" menu you switch into the currency definition mode.
Here, the currency key to be defined can be selected by pressing the key. All currency keys are located in the bordered region. An undefined and therefore unlabeled currency key can also be selected to define its currency.
After selecting the currency key, the currency definition form appears. There the parameters of the currency can be changed and entered. With the key "Delete.." in the form, a currency definition can be erased.
To define a currency, a currency symbol consisting of up to three charachters must be entered, which will be used as label for the currency key. Also, the conversion factor (exchange rating) related to the base currency has to be specified. The base currency is displayed if one exists. Any currency can be used as base currency by specifying conversion factor 1 for it.
Note: An alternative way to open the currency definition form for a currency key is to press the currency key for a period of at least 2 seconds and then releasing the key.
Example:
The currency US dollar should be added to the already defined currencies. The currency key above the key should be used. The conversion factor should be 0.9174.
In the menu "Options" select the menu item "Define Currency Key..." and then press the currency key you want to define.
The currency definition form appears where the currency symbol US$ and the conversion factor 0.9174 have to be entered. By pressing "OK" the currency definition form will be closed and the currency is defined.
The new currency is defined. It can be used:
InputDisplay
   0.
0.00
US$
11.
0.92
US$
0.
0.00
DEM
US$
64.5564.55
30.28
DEM
US$
6. INPUTS
Usually, the digits and operators will be entered by pressing the displayed keys. But all digits and some operators can also be entered using the Graffiti® region of the Palm device or pasted from the clipboard. Values can also be copied to the clipboard. Further it is possible to directly modify the contents of the memories in a special form.
Direct Manipulation of the Memories
Starting with version 1.26 of the SC-103PC the memory manipulation form can be opened via the menu item "Memory..." in the "Edit" menu. In this form the contents of all memories can be seen simultaneously and they can also be modified.
In the first line the actual display value is displayed. In the following line the contents of the independently accessible memory (M) is shown, followed by the 10 memories (1 to 9 and 0) which are assigned to the number keys.
The actual display value can be stored in the independently accessible memory by pressing the key and can be restored using the key .
In addition to the independently accessible memory there are 10 memory slots are available which can be modified with to . To read the contents of these memories you have to press the keys to .
The memory contents can also be changed directly using Graffiti®.
By pressing "OK" the memory form will be closed and all entered values will be written to the memories.
By pressing rsp. followed by a digit key or when selecting "OK", the entered values will be written back to the memories. But first it will be checked if the entered data is a valid value. If no valid value is entered an error requester will be displayed. It can be closed by pressing "OK" to correct the invalid input by hand. But if "Restore from memory" will be pressed, the last memory contents will be restored and the input will be lost.
In the shown example a wrong input is done for memory location 2.
Entering using Graffiti®
Following there is a table containing the keys which have been assigned a symbol which can be entered using Graffiti®
SCIENTIFIC and CURRENCY ModeLOGIC Mode
Key:Symbol:Key:Symbol:
to "0" to "9" to "0" to "9"
".", "," to "a" to "f", "A" to "F"
"_" "_"
" ", "C" " "
Backspace Backspace
"=", Enter "=", Enter
"^" (only SCIENTIFIC) "n", "N", "~"
"!" (only SCIENTIFIC) "o", "O", "|"
"x", "X", "^"
"m", "M", "%"
"l", "L", "<">
"r", "R", ">"
Data Exchange with the Clipboard
With the menu items in the menu "Edit", the value currently shown on the display can be cut or copied to the clipboard or a value in the clipboard can be pasted to the SC-103PC.
7. ERRORS
While in an error condition the display shows the symbol "E":
An error will be raised from a calculation or command which exceeds the capacity of the program. An error can be cleared by pressing the key.
Error Conditions
  1. If the absolute value of a calculation result is greater than 1.7976931348623×10308 (not in LOGIC mode).
  2. If a number is divided by 0 (zero) (e.g. 5  0  )
  3. If in CURRENCY mode a illegal calculation was entered.
  4. If the absolute value of a result of memory calculation is greater than 1.7976931348623×10308 (not in LOGIC mode).
  5. If the pending operation inclusive open parentheses exceeds 30 levels.
  6. For scientific functions an error occurs if the calculations exceed the following ranges:
Calculation Range
Numerical calculations:
For calculations with x, the value of x has to be in the given ranges:
-1.7976931348624×10308 < x<= -2.23×10-308 for a negative x
2.23×10-308 <= x < 1.7976931348624×10308 for a positive x
The displayed value for x will be limited by the number of displayable positions.
Functions:
FunctionRange of x
sin x
cos x
tan x
DEG: |x| < 1.7976931348624×10308
RAD: |x| < 1.7976931348624×10308
GRAD: |x| < 1.7976931348624×10308
Further only for tan x: (n = integer)
DEG: |x|  90(2n-1)
RAD: |x|  (/2)(2n-1)
GRAD: |x|  100(2n-1)
sin-1x
cos-1x
-1 <= x <= 1
tan-1x |x| < 1.7976931348624×10308
sinh x
cosh x
-710.47586007394 <= x <= 710.47586007394
tanh x -1.7976931348623×10308 <= x <= 1.7976931348623×10308
sinh-1x |x| < 1.3407807929943×10154
cosh-1x 1 <= x < 1.3407807929943×10154
tanh-1x |x| < 1
ln x
log x
ex -1.7976931348624×10308 < x <= 709.78271289338
10x -1.3407807929943×10154 < x <= 308.25471555991
1/x |x| < 1.7976931348624×10308; x  0
x2 |x| < 1.3407807929943×10154
0 <= x < 1.7976931348624×10308
n! 0 <= n <= 170 (n = integer)
DMSDEG
DEGDMS
yx
(yx=10x log y)
if y > 0, -2.23×10-308 < x log y < 308.25471555992
if y = 0, x > 0
if y < 0, x = integer
and 2.23×10-308 < x log |y| < 308.25471555992
(=101/x log y)
if y > 0, -2.23×10-308 < 1/x log y < 308.25471555992; x  0
if y = 0, x > 0
if y < 0, x or 1/x have to be integer and not zero,
and 2.23×10-308 < 1/x log |y| < 308.25471555992
x, y  r,
(x2+y2) < 1.7976931348624×10308
y/x < 1.7976931348624×10308  = tan-1(y/x)
r,   x, y
r < 1.7976931348624×10308 x = r cos
|r sin | < 1.7976931348624×10308 y = r sin
|r cos | < 1.7976931348624×10308
