| SCIENTIFIC CALCULATOR FOR THE PALM HANDHELD COMPUTER | |
| MODEL SC-102P |
INSTRUCTION MANUAL
With the program SC-102P you get a powerful and freely available scientific calculator for the Palm platform. Apart from scientific functions it also offers a full set of logical operations and conversions between different numeric systems. Therefore, it is especially useful for computer engineers and programmers. The program is designed in a way, that it simulates the visual and operational aspects of a true calculator, such that the user will be immediately familiar with its interface.
1. BACKGROUND |
The calculator program SC-102P can be executed on all devices equipped with the Palm Operating System version 2.0 or higher. In addition, it requires the freely available MathLib which is shipped as part of the calculator for your convenience. The calculator program automatically adapts to single and multi color devices. There are no different versions needed. The calculator SC-102P is shipped in three different languages: English, german and esperanto. They have variations only in the language of menu items and setting dialog boxes. The key and display labeling remains the same. To select the desired language, you have to install the proper program module. Since the name of the program module is the same for all languages, you can only have one language version installed at the same time.
The calculator program SC-102P as well as the MathLib have to be installed
on your Palm device. The SC-102P uses the MathLib for some of its
calculations.
If you don't know, how to install additional applications on your Palm
device, please refer to the instruction manual which is shipped
with your Palm device.
Installation Procedure:
To display the preferences window, select the menu item "Preferences...",
which is located in the "Options" menu.
Here you can control the flickering effect of the displayed numbers while
pressing an operator key like
. You can enable and
disable the flickering and additionally you can specify the amount of time
the display will be hidden to cause the flickering effect.
The flickering of the display serves as a visual feedback to show you that the calculator has accepted your input. In addition, the pressed key will be highlighted but this effect is often not noticable during fast input because of the delay time of the usually used liquid crystal displays.
The flickering effect of the display can be made stronger or softer.
If a greater hide time is selected, the display will be hidden for a longer
time and the flickering effect will be stronger.
Select a value according to your personal taste.
Note: If the flickering effect is enabled, then the display will be dark as
long as you press a key. If you release the key before the selected
hide time is reached, then the display will stay dark at least until the
selected hide time is over.
Not all keys, e.g. number keys, result in a flickering effect of
the display because some result in a visual display change anyway
and also to simply prevent a too nervous display.
1. OPERATING MODES |
The calculator SC-102P offers two general operating modes for different tasks. To select the desired operating mode there are the two vertically arranged fields at the right border of the display which are labeled SCIENTIFIC and LOGIC. To select the desired operating mode, tip on the corresponding field with the stylus. The field indicating the currently selected mode is shown in a dark background color.
| On color devices | On B/W devices | |||
| SCIENTIFIC mode | ![]() | ![]() | ||
| LOGIC mode | ![]() | ![]() |
In SCIENTIFIC mode, the SC-102P acts like a scientific calculator with 14 digits. In LOGIC mode, conversions between four different numeric systems are possible and basic arithmetic calculations and boolean operations can be performed.
2. SCIENTIFIC MODE |
The Palm handheld can be used like a calculator with 14 digits. For that purpose the program SC-102P has to be switched into SCIENTIFIC mode. You can activate the SCIENTIFIC mode by tapping on the corresponding field at the right border.
How the calculator in SCIENTIFIC mode looks like:
Now we will perform some simple calculations. Press the following keys and look at the display:
| Input | Display | ||||
| 123 | 123. | ||||
![]() | 123. | ||||
| 654 | 654. | ||||
![]() | 777. |
Did you get the right result? If not, press the
key and try the same calculation again.
Next, the value of pi (
) should be recalled.
The symbol "
" is located above the key
. Press the symbol.
![]() | 3.1415926535898 |
The Display now shows the value of
Now 104 should be calculated. For this operation the
function 10x will be used.
4 ![]() | 10000. |
Following the most important keys will be outlined:
* (Clear) (red rsp. dark key) |
If this key is pressed immediately after input of numerical data or
after a recall of the memory contents, this data will be cleared.
In any other case, pressing the
key clears
the operator and/or the numerical data which have been entered.
The content of the memory will not be cleared by pressing the
key.
| Input | Display | |||||
123 456 |
456. | |||||
![]() | 0. | |||||
786 ![]() | 912. | (123 + 789 = 912) | ||||
6 2 ![]() | 12. | |||||
![]() | 0. | |||||
5 ![]() | 8. |
The
key can also be used to clear an error condition.
5 0 ![]() | ![]() | ||
* (Display mode switch) |
With this key you can switch the display mode for the result of a calculation from floating point system (normal mode) to fixed point system (FIX), scientific notation (SCI), engineering notation (ENG) or vise versa.
| Input | Dispay | ||||
23 1000 ![]() | ![]() | ||||
* (specifies the number of decimal digits) |
In comibation with a number key, this key can be used to specify the number of
decimal digits (digits after the decimal point). Press the clear key
so that "0." is displayed. Press the key
, then "0.000" (FIX mode) appeares on the display.
1. Specification of 2 decimal digits.
2 | ![]() | ||
5 8 ![]() | ![]() |
2. Specification of 5 decimal digits.
5 | ![]() |
* (specifies the angular mode) |
This key is used to specify the angular mode for numerical data for trigonometric functions, inverse trigonometrc functions and coordinate transformations.
![]() | (Degree) | |||
![]() | ![]() | (Radian) | ||
![]() | ![]() | (Grad) | ||
![]() | ![]() | (Degree) |
180° = | DEG: Degree [°] RAD: Radian [rad] GRAD: Grad [g] |
* (transforms between angular modes) |
This key is used for transformations between angular modes and simultaneously specifies the angular mode for numerical data for trigonometric functions, inverse trigonometrc functions and coordinate transformations.
| 180 | ![]() | (Degree) | ||
* to , , and ![]() |
Used to enter numbers in exponential notation (an "E" following the entered number appears on the display).
4 3 | 4.E 003 | (4 × 103) | ||||
![]() | 4000. | |||||
![]() | -4000. |
Used to enter negative numbers (or to inverse the sign from
negative to positive).
1.23 ![]() | -1.23 | |||||
5 ![]() | -1.23E-005 | (-1.23 × 10-5) | ||||
![]() | -0.0000123 | |||||
![]() | 0.0000123 |
* (Backspace) |
With this key the last entered digit can be deleted.
| 125 | 125. | |||||
![]() | 12. | |||||
| 3 | 123. | |||||
478 | 478. | |||||
![]() | 47. | |||||
![]() | 4. | |||||
| 56 | 456. | |||||
![]() | 579. | (123 + 456 = 579) | ||||
1.456 19 | 1.456E 019 | |||||
![]() | 1.456E 001. | |||||
| 2 | 1.456E 012. | |||||
1000 ![]() | 1456000000. | (1.456 × 1012 / 1000 = 1456000000) |
Input:
12 45.6 32.1 789 741 213 ![]() | Result: 286.5 |
| a. | Input: 841 586 12 ![]() |
| Result: 41068.833333333 | |
| b. | Input: 427 54 32 7 39 2 ![]() |
| Result: 595.85714285714 |
Note that multiplication and division have priority over addition and subtraction. Internally, the calculator first calculates the multiplication and division.
Multiplication with a constant:Input: 3 5 ![]() | Result: 15 | |
Input: 10 ![]() | Result: 30 |
Division with a constant:
The value entered after the division sign acts as a constant.
Input: 15 3 ![]() | Result: 5 | |
Input: 30 ![]() | Result: 10 |
Note:
Depending on the priority, the calculator puts some calculations in pending state.
In case of chain calculations, the last calculation instruction,
taking into account the priority rules,
and the relevant numeric value are retained and can be used for further calculations
or as constants, respectively.
| a + b × c = | + bc | (Constant addition) | ||
| a × b ÷ c = | ÷ c | (Constant division) | ||
| a ÷ b × c = | a/b × | (Constant multiplication) | ||
| a × b - c = | - c | (Constant subtraktion) |
The independently accessible memory can be maintained with the three keys
and
. Before starting a calculation
clear the memory by pressing
and
If a value other than zero is stored in memory
" is displayed.
Input: 12 5 ![]() | |
| Result: 17 | |
For subtraction enter: 2 5 ![]() | |
| Result of this equation: -7 | |
Enter to recall memory contents: 10 will be displayed. | |
Input: 12 2 ![]() | |
| Result: 24 (replaces 10 in memory) | |
Input: 6 2 ![]() | |
Result: 4 : 28 | |
To subtract a value from memory contents, the keys
and
can be pressed.
In addition to the memory which can be modified with the
key,
there are 10 memory slots available which can be modified with
to
To read the contents of these memories you have to press the keys
to
just like
for the main memory.
To calculate trigonometric and inverse trigonometric equations and for
coordinate transformations the angular mode has to be assigned.
The assignment of the angular mode DEG, RAD or GRAD happens by pressing the
key.
| Exercise: sin 30° + cos 40° | ||
| Angular mode to DEG | ||
Input: 30 + 40 ![]() |
Result: 1.266044443119 | |
Exercise: cos 0,25![]() | ||
| Angular mode to RAD | ||
Input: 0.25 ![]() |
Result: 0.7071067811865 | |
| Exercise: sin-1 0,5 | ||
Input: 0.5 ![]() | Result: 30 | |
| Exercise: cos-1 -1 | ||
Input: 1 ![]() |
To input a negative number, press the key after entering the number. | |
Result: 3.1415926535898 (Value of ) | ||
The results of inverse trigonometric functions are only valid between the following ranges:
= sin-1 x, = tan-1 x |
= cos-1 x | |
DEG: -90 <= <= 90 [°] |
DEG: 0 <= <= 180 [°] | |
RAD: - /2 <= <= /2 [rad] |
RAD: 0 <= <= [rad] | |
GRAD: -100 <= <= 100 [g] |
GRAD: 0 <= <= 200 [g] |
| Exercise: sinh 4 | ||
Input: 4 ![]() |
Result: 27.289917197128 | |
| Exercise: sinh-1 9 | ||
Input: 9 ![]() |
Result: 2.8934439858859 |
| Exercise: 202 | ||
Input: 20 ![]() | Result: 400 | |
| Exercise: 33 and 34 | ||
Input: 3 3 ![]() |
Result: 27 | |
Input: 3 4 ![]() |
Result: 81 |
| Exercise: Square root of 25 | ||
Input: 25 ![]() | Result: 5 | |
| Exercise: Cube root of 27 | ||
Input: 27 ![]() | Result: 3 | |
| Exercise: Fourth root of 81 | ||
Input: 81 4 ![]() |
Result: 3 |
| Exercise: ln 21, log 173 | ||
| Natural Logarithms | ||
Input: 21 ![]() | Result: 3.0445224377234 | |
| Common Logarithms | ||
Input: 173 ![]() | Result: 2.2380461031288 |
| Exercise: e3,0445 | ||
Input: 3.0445 ![]() | Result: 20.999528813094 (see ln 21) | |
| Exercise: 102,238 | ||
Input: 2.238 ![]() | Result: 172.98163592151 (see log 173) |
| Exercise: 1/6 + 1/7 | ||
Input: 6 7 ![]() |
Result: 0.3095238095238 |
| Exercise: 170! | |
Input: 170 ![]() | |
| Result: 7.257415615308E 306 (= 7,257415615308 × 10306) | |
On calculating the factorial it is easily possible to overflow the calculation limits of the SC-102P which results in the error indication "E". The section Calculation Range discusses the calculation limits of the calculator.
| Exercise: 8P3 = 8!/(8-3)! | |
Input: 8 8 3 ![]() | |
| Result: 336 | |
| Exercise: 45% of 2780 (2.780 × 45/100) | ||
Input: 2780 45 ![]() |
Result: 1251 | |
| Exercise: 200 - 200 × 30/100 | ||
Input: 200 30 ![]() |
Result: 140 |
To convert an angle or time (°, ', ", rsp. hours, minutes, seconds) to its decimal equivalent the degrees have to be given as integer portion and the minutes and seconds as decimal digits.
Exercise: Transformation of 12°47'52" to its decimal equivalent
Input: 12.4752 ![]() |
Result: 12.797777777778 |
When converting decimal degrees to the equivalent
degrees/minutes/seconds, the answer is broken down:
integer portion = degrees; 1st and 2nd decimal digits = minutes;
3rd and 4th digits = seconds; and 5th through end decimal digits
are decimal seconds.
Exercise: Conversion of the decimal angle 24.7256 to its degree/minute/second equivalent
Input: 24.7256 ![]() | Result: 24.433216 or 24°43'32" |
A horse has leap times of 2 minutes 25 seconds, 2 minutes 38 seconds and 2 minutes 22 seconds. What is the average running time?
Input:
0.0225 0.0238
0.0222 ![]() | |
| Result 1: 0.1236111111111 | |
Input: 3 ![]() | |
| Result 2: 0.0412037037037 | |
Input: ![]() | |
| Result 3: 0.0228333333333 or the average time is 2 minutes 28 seconds. | |
Converting rectangular coordinates to polar (x, y
r,
DEG: RAD: GRAD: |
0 <= | | <= 1800 <= | | <= ![]() 0 <= | | <= 200 |
Convert rectangular coordinates x = 6 and
y = 4 to polar coordinates.
Angular mode: DEG
Input: 6 4 ![]() |
Result: 7.211102550928 (r) | |
Input: ![]() |
Result: 33.69006752598 ( ) |
Calculate the magnitude and direction (phase) in a vector i = 12 + j9
Input: 12 9 ![]() |
Result: 15 (r) | |
Input: ![]() |
Result: 36.869897645844 ( ) |
Converting polar coordinates to rectangular
(r,
x, y).
Solve for P(14,
/3), r = 14,
0
/3
Angular mode: RAD
Input: 3
14
| Result: 7 (x) | |||||||||
Input: ![]() | |||||||||
| Result: 12.124355652982 (y) | |||||||||
/3
is entered first and is replaced by r = 14 by
pushing the
key after entering r.
Usage of the parenthesis keys
and
is required if series of calculations
are combined together and the priority of operations has to be changed.
After pressing the
key, "( )" is displayed in the
top of the display.
Calculations between parenthesis have priority over all other calculations.
The parentheses can be nested more than once. First the calculations
between the innermost parenthesis will be made.
| Exercise: 12 +42 ÷ (8 -6) | |
Input: 12 42 8 ![]() | |
| Result: 33 | |
| Exercise: 126 ÷ {(3 + 4) × (3 - 1)} | |
Input: 126 3 4 3 1 ![]() | |
| Result: 9 | |
Hint:
It is not neccessary to close the parenthesis immediately before
the
key (or
key).
The number of decimal digits in a calculation result can be specified; to do this
use the
key in combination with the keys
to
. In this case, the display has to be switched to
fixed point (FIX), scientific notation (SCI) or engineering notation (ENG).
![]() | No decimal digits. (The number will be roundet to the next integer number.) | |
![]() | One decimal digit. (The number will be roundet to the first decimal digit.) | |
![]() | Nine decimal digits. (The number will be roundet to the 9th decimal digit.) |
To clear the TAB setting (definition of places after decimal digit) leave the calculator application and restart it again. Then the normal display will be shown again.
Example:
9 | |||
0.5 9 ![]() |
![]() | 0.055555556 (FIX mode) (The number is roundet to the 9th place after decimal digit.) | |
![]() | 5.555555556E-002 (SCI mode) (The mantissa is roundet to the 9th place after decimal digit.) | |
![]() | 5.556E-002 (SCI mode) (The mantissa is roundet to the third place after decimal digit.) | |
![]() | 55.556E-003 (ENG mode) | |
![]() | 0.0555555555556 |
The program is provided with a function that judges the priority level of individual calculations; thus, you can enter your calculations in the same order as in a given mathematical formula. The following table shows the priority level of individual calculations.
Example:
Key operation and sequence of calculation in
5 + 2 × sin 30 + 24 × 53 =
The numbers
show the sequence of the
calculations.
When calculations with higher priority are executed, those with lower priority must be saved in the meantime.
The program is equipped with additional memories for such pending operations.
As these memories are also used for calculations with parentheses,
calculations can be performed according to a given mathematical formula
unless parentheses and pending operations exceed 30 levels in total.
DEG,
D.MS, etc.) are
calculated immediately after key operation without being retained.
Example:
![]() | Pending of 1 level |
![]() | Pending of 2 levels |
![]() | Pending of 3 levels |
![]() | By pressing the
key, 3 pending levels are reached. After pressing the
key the calculations "yx"
will be performed with highest priority and "×" with the same priority.
Thus, after pressing the key, two pending levels remain. |
Example:
| i) | ![]() | 4 numbers and operations stay pending. |
| ii) | ![]() | After pressing
the key first the calculation between parentheses
3 - 4 ÷ 5 will be performed;
2 calculations stay pending. |
3. LOGIC MODE |
Computer engineers and programmers are in need of simple conversions between various numeric systems as well as for calculations with boolean logic. With the calculator SC-102P this problem is solved by providing the LOGIC mode. The LOGIC mode can be selected by tapping of the corresponding field at the right border.
How the calculator looks in LOGIC mode (hexadecimal notation selected):
The calculator can operate with integer values up to a bit width of 32 bits in four different numeric systems.
To convert a number to its hexadecimal equivalent; at the same time
the calculator will be switched to hexadecimal notation HEX.
( is shown in the displayed.) |
To convert a number to its decimal equivalent; at the same time
the calculator will be switched to decimal notation DEC.
( is shown in the display.) |
To convert a number to its octal equivalent; at the same time
the calculator will be switched to octal notation OCT.
To convert a nubmer to its binary equivalent; at the same time
the calculator will be switched to binary notation BIN.
Exercise:
Conversion from decimal 30 to hexadecimal notation:
Press
key if calculator is not currently
in decimal notation (
is displayed).
30 ![]() | 1E |
Exercise:
Further conversion of hexadecimal 1E to binary format:
![]() | 11110 |
The hexadecimal notation system is mainly used in computer programming. The base for a hexadecimal number is 16; hexadecimal numbers consist of the digits 0 to 9 and the major letters A to F, which stand for the numbers 10 to 15 in the decimal system.
Keys for the letters A to F will be shown as soon as the calculator is
in hexadecimal notation.
The symbol |
In LOGIC mode even in decimal notation only integer values with a bit width of a maximum of 32 bits can be handled.
In decimal notation only the keys for the digits 0 to 9 are shown.
The symbol |
The base for a octal number is 8; octal numbers consist of the digits 0 to 7.
In octal notation only the keys for the digits 0 to 7 are shown.
The symbol |
The binary notation system is mainly used in computer programming. The base for a binary number is 2; binary numbers consist of the digits 0 and 1.
In binary notation only the keys for the digits 0 and 1 are shown.
A smaller font is used so all of the 32 positions can be displayed in
one row. Additionally, a ruler is shown above the digits to support the
identification of nibbles, bytes and words.
The symbol |
In the binary notation system a digit can be swapped from 0 to 1
and vice versa by tapping on the digit position below the ruler.
If an empty area is tapped then the digit 1 will be set there.
With this functionality it is possible to directly modify the bits
of a value.
The calculator can be switched to bit widths of 8, 16 and 32 bits
which are commonly used in the computer industry. With the
key the next higher and with the
key the next lower bit width is selected.
The currently selected bit width is shown in the display.
With the
key the display of the numbers can be
toggled so that they are shown with or without leading zeros.
Press the
key once to show numbers with leading
zeros filled to the selcted bit width. Press the
key
once more to switch back to normal number display.
Example:
Settings:
notation,
| Input | Display | ||||||
1AB ![]() | 1AB | ![]() | |||||
![]() | 01AB | ![]() | |||||
![]() | 0000 01AB | ![]() | |||||
AB8 ![]() | 0000 0AB8 | ![]() | |||||
456 ![]() | 002E 79D0 | ![]() | |||||
![]() | 2E 79D0 | ![]() |
With the
key, the calculator can be switched
between signed and unsigned mode. In the display the symbol
appears if the signed mode is active.
Signs are only shown in HEX, DEC and OCT notations. In the BIN notation only the bits are shown, always without a sign.
With the
key the sign of a number can be changed.
If the sign of a positive number is changed, the 2's complement
of the number is calculated. In signed mode the number will then be
shown as negative number in unsigned mode as 2's complement.
Example:
Settings:
notation,
180 ![]() | -180 | ![]() | |||||
![]() | FE80 | ![]() | |||||
![]() | 1111111010000000 | ![]() |
The selected bit width in combination with the sign mode has influence on the number range which can be handled. In contrast to the SCIENTIFIC mode, too big or too small numbers do not lead to an error condition in LOGIC mode but to an overflow.
| Bit Width | Num. Sys. | Sign Mode | Number Range | ||
| 8 BIT | HEX | 0 | ~ | FF | |
| 8 BIT | HEX | SIGN | -80 | ~ | 7F |
| 8 BIT | DEC | 0 | ~ | 255 | |
| 8 BIT | DEC | SIGN | -128 | ~ | 127 |
| 8 BIT | OCT | 0 | ~ | 377 | |
| 8 BIT | OCT | SIGN | -200 | ~ | 177 |
| 8 BIT | BIN | 0 | ~ | 11111111 | |
| 8 BIT | BIN | SIGN | 0 | ~ | 11111111 |
| 16 BIT | HEX | 0 | ~ | FFFF | |
| 16 BIT | HEX | SIGN | -8000 | ~ | 7FFF |
| 16 BIT | DEC | 0 | ~ | 65535 | |
| 16 BIT | DEC | SIGN | -32768 | ~ | 32767 |
| 16 BIT | OCT | 0 | ~ | 17 7777 | |
| 16 BIT | OCT | SIGN | -10 0000 | ~ | 7 7777 |
| 16 BIT | BIN | 0 | ~ | 1111111111111111 | |
| 16 BIT | BIN | SIGN | 0 | ~ | 1111111111111111 |
| 32 BIT | HEX | 0 | ~ | FFFF FFFF | |
| 32 BIT | HEX | SIGN | -8000 0000 | ~ | 7FFF FFFF |
| 32 BIT | DEC | 0 | ~ | 4294967295 | |
| 32 BIT | DEC | SIGN | -2147483648 | ~ | 2147483647 |
| 32 BIT | OCT | 0 | ~ | 377 7777 7777 | |
| 32 BIT | OCT | SIGN | -200 0000 0000 | ~ | 177 7777 7777 |
| 32 BIT | BIN | 0 | ~ | 11111111111111111111111111111111 | |
| 32 BIT | BIN | SIGN | 0 | ~ | 11111111111111111111111111111111 |
Exercise:
Solve of 250 + 15 with unsigned 8 bit arithmetic (overflow calculation):
Press the
key to select decimal notation
is shown in the display).
Press the
until
is shown in display.
With the
key select unsigned mode
(symbol
cleared in display).
250 15 ![]() |
9 | ![]() |
Exercise:
Display the result of the last calculation in binary notation:
![]() | 1001 | ![]() |
The arithmetic operations addition, subtraction, multiplication and division can be used like in SCIENTIFIC mode. But only integer values can be handled.
Exercise:
Addition of two hexadecimal numbers
A4 + BA =
![]() | 0 | ![]() | |||||
A4 BA ![]() |
15E | ![]() |
Exercise:
4 × 4 =
4 ![]() |
10 | ![]() |
Exercise:
32 bit multiplication of the octal number 73 with the binary number 110
and display of the result as a decimal number
73 oct × 110 bin =
Press
until
is shown in display
73 ![]() | 111011 | ![]() | |||||
110 ![]() | 101100010 | ![]() | |||||
![]() | 354 | ![]() |
Exercise:
(12 + D) × B =
12
D ![]() B ![]() |
155 | ![]() |
Exercise:
| 43A | - | 3CB | = | |
| +) | A38 | - | 2FB | = |
| total | ||||
![]() | 0. | ![]() | |||||
43A 3CB ![]() |
6F | ![]() | |||||
A38 2FB ![]() |
73D | ![]() | |||||
![]() | 7AC | ![]() |
The following hints have to be noted:
Examples:
Input: E 3 ![]() |
Result: 4 | ![]() | ||
Input: B 3 2 ![]() |
Result: 6 | ![]() |
With the modulo operation the remainder of a division can be computed.
Input: E 3 ![]() |
Result: 2 | ![]() |
By pressing the
key it is possible to
calculate the complement of a number in a simple way.
Settings: Unsigned mode (symbol
is not shown,
notation,
Input: AB ![]() |
Result: FFFF FF55 | ![]() |
The operators of the boolean algebra AND, OR, XOR (exclusive or) and NOT can be used. In a logical operation two numbers will be transformed to binary representation (2's complement) and the logical relation will then be evaluated for every bit pair.
The following section will shown the results of the logical operators for these bit evaluations:
| AND | OR | XOR | NOT | |||||||||||||||||||||||||||||||||||||||||||||||||||
After every bit pair has been assigned the corresponding result (a 1 or a 0) according to the above table, the resulting binary number will be converted back to the selected numeric system. This number is the result of the logical operation.
Example:
notation,
, please perform the following calculations:
41 AND 27 ![]() gives 9 | ![]() |
Input: 41 27 ![]() |
Result: 9 | ![]() | 41 OR 27 ![]() gives 59 | ![]() |
Result: 59 | ![]() | 41 XOR 27 ![]() gives 50 | ![]() |
Result: 50 | ![]() | NOT 3 ![]() gives -4 (2's complement) | ![]() |
Input:3 ![]() |
Result: -4 | ![]() | |||
NOT x can generaly be computed with the equation NOT x = -(x + 1).
and
it is possible
to perform bit shift operations. Thereby the value will be transformed
to binary representation and the single bits will be shiftet to the left or the right
by the given amount. The result will be transformed back to
the selected numeric system which yields the result of the operation.
During the bit shift right operation the single bits of a value will be shiftet to the right by the given amount of positions. This is equivalent to a division by the power of 2.
Example:| decimal | binary | ||
| before shifting | 80 | 01010000 | |
| after shifting | 10 | 00001010 |
| Input: | Display: | ||||||
80 3 | 10 | ![]() |
In signed mode (
) an arithmetical shift right
will be performed whereas in unsigned mode a logical shift right is executed.
On a logical shift right the single bits will be strictly shifted
| Input: | Result: | ||||||
120 ![]() | -120 | ![]() | |||||
![]() | 10001000 | ![]() | |||||
1 ![]() | 11000100 | ![]() | |||||
![]() | -60 | ![]() |
![]() | 196 | ![]() | |||||
2 ![]() | 49 | ![]() | |||||
![]() | 110001 | ![]() |
During the bit shift left operation the single bits of a value will be shiftet the given amount of positions to the left. This is equivalent to a multiplication with the power of 2.
| before shifting | 3 | 0000 0011 | |
| after shifting | 12 | 0000 1100 |
3 2 | 12 | ![]() |
During the processing of complex expressions the calculator follows a set of predefined priorities which determine the sequence in which the operators have to be applied. In LOGIC mode, the same rules for priority of operators and parenthesis are valid as described in SCIENTIFIC mode in section Priority Levels of Operations but the additional boolean operators have to be taken into account:
1. Functions like not or x2
2. ×, ÷, mod
3. +, -
4. «, »
5. and
6. xor
7. or
8. =, M+
(Calculations which are on the same priority level are
executed in sequence.)
4. INPUTS |
Usually, the digits and operators will be entered by pressing the displayed keys. But all digits and some operators can also be entered using the Graffiti® region of the Palm device or pasted from the clipboard. Values can also be copied to the clipboard.
Following there is a table containing the keys which have been assigned a symbol which can be entered using Graffiti®
| SCIENTIFIC Mode | LOGIC Mode | |||||
| Key: | Symbol: | Key: | Symbol: | |||
to ![]() | "0" to "9" | to ![]() | "0" to "9" | |||
![]() | ".", "," | to ![]() | "a" to "f", "A" to "F" | |||
![]() | "_" | ![]() | "_" | |||
![]() | " ", "C" | ![]() | " " | |||
![]() | Backspace | ![]() | Backspace | |||
![]() | "=", Enter | ![]() | "=", Enter | |||
![]() | "^" | ![]() | "n", "N", "~" | |||
![]() | "!" | ![]() | "o", "O", "|" | |||
![]() | "x", "X", "^" | |||||
![]() | "m", "M", "%" | |||||
![]() | "l", "L", "<"> | |||||
![]() | "r", "R", ">" | |||||
The Graffiti® state indicator is located in the lower-right corner.
With the menu items in the menu "Edit", the value currently shown on the display
can be cut or copied to the clipboard or a value in the clipboard
can be pasted to the SC-102P.
5. ERRORS |
While in an error condition the display shows the symbol "E":
An error will be raised from a calculation or command which exceeds the
capacity of the program.
An error can be cleared by pressing the
key.
0
-1.7976931348624×10308 < x<= -2.23×10-308 for a negative x
2.23×10-308 <= x < 1.7976931348624×10308 for a positive x
The displayed value for x will be limited by the number of displayable positions.
Functions:
| Function | Range of x | |||||||||
| sin x cos x tan x |
DEG: |x| < 1.7976931348624×10308 RAD: |x| < 1.7976931348624×10308 GRAD: |x| < 1.7976931348624×10308 Further only for tan x: (n = integer) DEG: |x| 90(2n-1)RAD: |x| ( /2)(2n-1)GRAD: |x| 100(2n-1) |
| sin-1x cos-1x |
-1 <= x <= 1 | |||||||||
| tan-1x | |x| < 1.7976931348624×10308 | |||||||||
| sinh x cosh x | -710.47586007394 <= x <= 710.47586007394 | |||||||||
| tanh x | -1.7976931348623×10308 <= x <= 1.7976931348623×10308 | |||||||||
| sinh-1x | |x| < 1.3407807929943×10154 | |||||||||
| cosh-1x | 1 <= x < 1.3407807929943×10154 | |||||||||
| tanh-1x | |x| < 1 | |||||||||
| ln x log x |
2.23×10-308 <= x < 1.7976931348624×10308 | |||||||||
| ex | -1.7976931348624×10308 < x <= 709.78271289338 | |||||||||
| 10x | -1.3407807929943×10154 < x <= 308.25471555991 | |||||||||
| 1/x | |x| < 1.7976931348624×10308; x 0 |
| x2 | |x| < 1.3407807929943×10154 | |||||||||
0 <= x < 1.7976931348624×10308 | |||||||||
| n! | 0 <= n <= 170 (n = integer) | |||||||||
DMS DEGDEG DMS |
| yx (yx=10x log y) |
![]() ( =101/x log y) |
x, y r, ![]() |
r, x, y |
